Fuel lines that last - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2012, 02:07 PM
spinn's Avatar
If you run your own fuel lines what do you use? Most hotrods are built beyond the 5/16-3/8" metal prebent lines that are remade very well in SS. Not a racer but always keep the rubber line joining parts inches at best. My builds have used long oversized prebent SS lines from tank to pump. The melling mechanical 110gph pump is -6 an a small rubber link is a joint between the tank sender and tank line , then tank line and pump inlet. After the inlet it is -6 AN braided lines that are rubber insides. Braided all the way to the the carb no rubber there. Never had leaks. Are braided compareable to SS tubing?
What are is the longevity of that system. The SS tube I anticipate no problem. The Braided rubber center line has me guess?ng?
One system has been in place sealed no leaks for 12 years.
Old 11-17-2012, 02:23 PM
Richiehd's Avatar
JS-70
Ive got stainless braided on my Skiff, no issues for many years. I understand Methanol will eat them on the inside, but so far no issues.
Old 11-17-2012, 05:28 PM
Banned
never rust, and easier to work than s/s and cheaper
AGS Company - NiCopp Products
Old 11-18-2012, 10:49 AM
1971BB427's Avatar
I use steel, but not SS. Rust isn't a big issue where I live, so steel lasts forever. My '71 still has it's original steel lines.
Old 11-19-2012, 02:47 PM
Pantaz's Avatar
Originally Posted by spinn View Post
... Are braided compareable to SS tubing? ...
No. The stainless steel braid covers only the outside, the inside is rubber*. I believe CPE (chlorinated polyethylene) is the lining recommended for alcohol fuels.
* There are many types of s/s braided hose made with a variety of materials for compatibility with different fluids, temperatures, and pressures.
Seeking Advice: Installing Fuel Pump & Fuel Lines horvath Engine 40 04-15-2011 10:12 AM
On Fuel lines... unstable Engine 2 05-02-2010 01:47 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
fuel pump/ fuel lines bad apple Engine 2 03-12-2009 10:43 PM
Fuel Lines joeford Hotrodding Basics 20 05-27-2007 07:31 AM
