Fuel mixture sensors - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2002, 02:58 PM
Maverick's Avatar
Post Fuel mixture sensors
Has anyone ever used one of those rich/lean fuel mixture gizmos?? Like this one? Just courious if they work?
http://store.summitracing.com/produc...earchtype=ecat
Old 11-19-2002, 04:12 PM
4 Jaw Chuck's Avatar
Post
They work fine, a little to much lag time to the needle deflection for my liking but they work. I use a digital voltmeter with a type K thermocouple, instantaneus reaction time.
— Han Solo
Old 11-19-2002, 04:17 PM
Canzus's Avatar
a red wool sock on his dinger
Post
[quote]Originally posted by 4 Jaw Chuck:
<strong>I use a digital voltmeter with a type K thermocouple, instantaneus reaction time.</strong><hr></blockquote>
Yeah, Okay, so what temp is rich/lean??
Those gages work in a very narrow band
around lambda (stoich), but won't help
very much if you're way to rich or way
to lean...
Old 11-19-2002, 05:09 PM
roys63's Avatar
Post
This reads the same as a O2 sensor volts
[ November 19, 2002: Message edited by: roys63 ]</p>
Old 11-19-2002, 07:53 PM
Question
Good question Maverick,
I've wondered how accurate they would be?
I've seen them in a digital type with l.e.d's that light up also.
Tom,
Old 11-19-2002, 08:08 PM
Post
Readings are output in a voltage band from 0-1.0 Volts, 0.5 volts being stoichiometric. Having a voltmeter accurate enough to read 0.01 volts is needed for accuracy. Type K thermocouple is far more accurate and responsive, additionally it reads in degrees Celcius or Farenheit with my meter (adapter with two inputs).
— Han Solo
Old 11-20-2002, 06:52 AM
Maverick's Avatar
Post
Thanks guys! Think I am going to go with something like the MDS unit that has the led lights, When I get to that point! Seems like it will take the guess work out of it.
