Fuel pressure? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2010, 10:27 PM
396chevelle's Avatar
Fuel pressure?
I have a performer rpm fuel pump rated at 110gph of fuel and produce up to 6 psi. No Regulator Required! My pump is putting out 9 psi unless my gauge is bad which I am going to change to make sure, but there is no bog or signs of to much fuel. If it is actually 9 psi would you recommend getting a regulator for a pump that supposedly doesn't require one or let ride? Thanks,
Old 12-04-2010, 10:52 PM
techinspector1's Avatar
Wiki Edits: 326
Edelbrocks, Carters and Quadrajets will tolerate a max of 5 1/2 lbs. Holleys will tolerate a max of 6 1/2. Adjust accordingly with a known good pressure gauge.
Old 12-04-2010, 10:55 PM
001mustang's Avatar
Edelbrock fuel pump (new design) looks suspiciously like holley fuel pump.
My edelbrock carb specifies 6psi max.
Edelbrock claims their pump produces only 6 psi thus you must purchase their pump or else install regulator w/ other brand. Another poster also states this pump produces more than 6 psi. I run edelbrock pump and carb w/ no regulator and no problems. My pressure indicator is not accurate enough to be sure what exact max psi is; looks like about 7 psi according to poorly ranged PI.
Old 12-05-2010, 04:37 PM
Turns out the gauge was off a little, but not much. I got a regulator to put on it and dialed it back to 5.5 psi all it did was hesitate when the gas hit the floor. I bumped it up to 6.5 psi and all was good. Thanks for the replies!
Old 12-05-2010, 06:14 PM
Same here, My Edelbrock mechanical fuel pump performer rpm110 gpm produced almost 8lbs. I put a regulator on it and dialed it back to 6lbs. I think everyone should have a regulator just for insurance reasons. There is no way that a mass produced pump can be accurate on everyone.
Lou
Fuel pressure beaker60 Engine 5 03-16-2009 03:10 AM
Where the heck is my fuel pressure goin? handyforgod General Rodding Tech 4 01-18-2009 08:52 AM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 03:35 PM
Fuel Pressure GCD1962 Engine 4 12-27-2007 07:46 AM
Measuring Fuel Pressure Waterhead Engine 7 06-20-2003 08:39 PM
