Fuel Pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 05:05 PM
jeffmc's Avatar
jeff mc
Last journal entry: 1941 Dodge Custom
Fuel Pressure
Hello all,
Hows much fuel pressure dio I need for a 87 305 tuned port .I've some wildly different opinions on the answers, some are as low as 35psi and as high as 80 .
The pump is a rail mounted pump located just outside the tank. Its putting out 34psi at the feul rail.
I had the car running back in the spring ,but had a serious medical problems that took me out for the summer and fall. But after sitting for the summer I can't seem to get it to start,tries ,but no go
I'm thinking the fuel pump only because it just don't sound the same .
Thanks
Jeff
Old 01-14-2012, 09:08 PM
crazypj's Avatar
I fake being smart
Majority of FI systems run between 43and 60 PSI.
35 seems a bit low
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 02:51 PM
Quadrajet 4bbl/Edelbrock street fuel pump- too much fuel pressure? Bob Turner Engine 2 11-30-2008 12:50 AM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 04:35 PM
fuel pressure ict55chevy Engine 2 12-16-2006 05:08 PM
fuel pressure jtcamaro Engine 1 06-01-2004 01:29 AM
