fuel pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2004, 12:10 AM
jtcamaro's Avatar
fuel pressure
How much fuel pressure should i run to my 750 edelbrock? when i do a burnout right when the tires get burning it will fall on its face like its out of gas but after a few sec.s it will start running again.
I think the fuel bowls are going dry under heavy acceleration. the fuel pressure is set at 7psi. right now.
what do you guys think?
Old 06-01-2004, 12:29 AM
77z's Avatar
77z 77z is offline
Go big or go home
Do you still have 7 psi when it falls on its face ? Its hard to say whats happening unless you know 100% that your keeping the pressure at the regulator / carb. I dont have much experiance when it comes the the edelbrock carbs but have played a bit with the carter version and well 7 psi fed my 454 no problems does it also fall on its face from a launch ? or just the burnout
Mike
77 Z28 496 9 inch
10.23 @ 129
