fuel pressure 5.3 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2008, 07:16 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
anyone knows the fuel pressure for a 2001 5.3 chevy truck?
Thanks.
Augusto.
Old 05-01-2008, 09:27 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Key on Engine off should be 55-62 PSI, At idle 52-59 PSI.
Old 05-01-2008, 09:40 PM
Augusto's Avatar
really that high? I thought it was 43-45, I was going to use a bosch fuel pump, but I think it can not sustain that much pressure.
Augusto.
Old 05-01-2008, 09:45 PM
My 2 cents worth
Wiki Edits: 3
Yes it is that high, and I recommend getting the factory pump. What is your pressure running now? Are you having a starting, or drive-ability problem?
Old 05-01-2008, 09:58 PM
Augusto's Avatar
damn, seems like I must go with the original pump, it costs $ 430 here and the bosch pump is only $ 40
unless I can find cheap a bosch pump for the BMW's that had the K-jetronic injection, it worked at 75 psi.
the truck is dead now, no pressure,
thanks for the advice, do you have any suggestions?
Augusto.
Old 05-01-2008, 10:00 PM
My 2 cents worth
Wiki Edits: 3
Have you checked for power at the pump? It could be a blown fuse, or defective fuel pump relay.
Old 05-01-2008, 10:05 PM
Augusto's Avatar
yes, I took the pump out, it's fried.
Augusto.
Old 05-01-2008, 10:07 PM
My 2 cents worth
Wiki Edits: 3
That's to bad I feel for you.
Old 05-01-2008, 10:09 PM
My 2 cents worth
Wiki Edits: 3
Could you get it cheaper by ordering it on-line?
Old 05-01-2008, 10:16 PM
Augusto's Avatar
probaby but shipping plus customs duties plus warranty issues.... is not worth,..
chevy dealers here charge a lot but at least they are here to support what they sell.
What do you think of the BMW pump?
Augusto.
Old 05-01-2008, 10:18 PM
My 2 cents worth
Wiki Edits: 3
It could be worth a shot! If it truly is a high pressure pump.
Old 05-01-2008, 10:22 PM
Augusto's Avatar
gracias amigo!
I'll try to get one and see if it works, if not I'll be $ 430 poorer.
Saludos from the middle of the planet.
Augusto.
Old 05-01-2008, 10:24 PM
My 2 cents worth
Wiki Edits: 3
Your welcome.
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 09:51 PM
What's the best carb & fuel tank replacement for a 1955 Chevy 235 straight six? islandman Engine 5 09-17-2011 11:50 PM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 04:35 PM
Low fuel pressure oldred General Rodding Tech 12 04-01-2008 12:41 PM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 11:27 AM
