Fuel pressure creap????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2004, 02:26 PM
84Z 84Z is offline
Gas Raper
Hi, I tuned my fuel pressure regulator for my holley blue to 6 spi when the car is off. When I turn the car on, the fuel pressure shoots up to 12 but the car still runs normal... What's going on, and is it fine to leave it?
Old 10-15-2004, 02:30 PM
poncho62's Avatar
Wiki Edits: 5
Set it when it's running. If it's not running, there is no pressure. Some needles and seats in the carb will hold at 12 lbs, but some won't. Turn it down.
Old 10-15-2004, 02:48 PM
84Z 84Z is offline
Gas Raper
I have an electronic switch to activate ther fuel pump, and I set it that was to 6, when the cars on, I can't adjust the fuel pump, it doesn't change much for some reason...
Old 10-15-2004, 04:13 PM
camaroman7d's Avatar
Fuel pressure will vary depending on tempature and altitude. Don't expect it to stay right where you set it running or not. Once the pump heats up the pressure will drop some too. It is not only Holley pumps that do that. However, if you are using a Holley regulator I suggest you ditch it ASAP they are typically not very good. I much prefer the Mallory regulators (BG's are good too).
Royce
Old 10-15-2004, 07:38 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
He is saying that when the engine is off, the fuel pressure is 6 psi, and when he starts it the fuel pressure goes up to 12 psi.
That doesn't make a lot of sense since when the engine is off it will build pressure but when it is running it will bleed of pressure due to the engine's fuel consumption. I do agree with the thought on irregularities...but 6 psi positive?
Old 10-15-2004, 09:14 PM
Well when the engine is not running you do not have the alternator charging (increasing) the voltage, this could have something to do with why he is seeing a lower pressure when the engine is not running. You should always adjust the fuel pressure with the engine running.
Royce
Old 10-16-2004, 12:08 AM
84Z 84Z is offline
Gas Raper
I have a brand new battery in there, I mean just bought and put in. Anyways as I said, the car seems to run fine at 12, I've heard **** about the car dying out from psi around 12, but mine was fine...
Old 10-16-2004, 06:30 AM
Lonestar's Avatar
I would verify accuracy of the gauge. Holleys don't tend to do well over 7 psi...that is already enough pressure to unseat the fuel inlet valve on most Holleys.
The 2 +- volts difference between a fully charged battery (12.6) and running voltage (around 14.5) would not make that big of a difference.
