Hello All, I've become caretaker to kind of an interesting Volvo wagon. It has until just recently been a very easy-to-drive sort of car. Lots of double-takes, too.
After warm up:
-the car experiences a fair degree of surge at idle from 900 down to 300 or so -- Possible too lean?
-fuel pressure 25-27 psi (Auto-Meter electric off the BBK regulator)
Question- What should I see pressure-wise for this set-up?
Thanks, Jeff
1993 Volvo 940 wagon w/347ci stroked Ford V8, Ported GT-40 aluminum heads, 10.2 to 1 CR, Track Heat manifold, JBA shorty headers into a single 3" exhaust, Dodge Reidy Custom cam w/ 1.6 to 1 roller rockers, FMS Cobra computer w/ TwEECer RT, 30 lb injectors, and 75mm Pro-M MAF, BBK 73 throttle body, BBK fuel pressure regulator, K&N filter, cold air box, FMS underdrive pulleys, DCC VariableSpeed Fan Relay, 155lph Volvo fuel pump
Tremec 3550II gearbox, SPEC clutch, 3.54 gears, PowrLok LS diff, ipd bars and springs, Koni dampers, 13" Wilwood rotors & calipers in front, 245x45's on 17x9 and 225x50's on 17x7.5, 3375 lbs dry
After warm up:
Thanks, Jeff
