Fuel Pressure Gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 06:34 PM
Fuel Pressure Gauge
I Just Got A 71 El Camino 350 Its Got A 750 Holley With A Dual Feed And Has A Pressure Gauge. The Needle Fluctuates A Lot When Running. Cant See The Needle Fippin So Bad. The Car Runs Steady So Im Leanin Toward A Defective Gauge. Iv Had These Before But Always Had A Steady Needle. Thanks Gary
Old 07-11-2010, 06:58 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
More then likely it is just the gauge, Mine done the same thing swithed it out and now it works just fine.JMO
Cole
Old 07-11-2010, 07:19 PM
Topic related info:
The oil-filled gauges are good for vibration environments like when engine mounted. The problem with the oil-filled gauges is that they are a sealed design to keep the oil inside. This makes the gauge reading change with different temperatures. My oil-filled gauge will read 7 psi when cold but only about 3 psi when heated by the engine. The pressure inside the gauge changes. To fix this, there must be a way of relieving that pressure back to atmospheric.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
mounting fuel pressure gauge binder47 Engine 2 03-22-2009 09:16 AM
Fuel pressure beaker60 Engine 5 03-16-2009 04:10 AM
Where the heck is my fuel pressure goin? handyforgod General Rodding Tech 4 01-18-2009 09:52 AM
