Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - fuel pressure issue help
Old 03-09-2011, 11:38 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
6 psi should be more than enough pressure, 7 psi is about the most a Holley type needle/seat/float assembly will handle without fuel getting blown past it.
Liquid-filled guages are notoriously sensitive to heat making them show a false pressure drop read low, I never trust them to read right warm. Once pressure is set cold there is really no reason it should change when warm.
