Fuel Pressure Port - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2011, 09:59 PM
Fuel Pressure Port
Anybody ever install an EFI style schrader valve for checking fuel pressure on a scratch built fuel system?
If so, was it a special fuel rated valve or just a common tire fill unit?
Old 02-15-2011, 11:09 PM
I am sure the seals inside it are made for gasoline, and whatever other crap they are putting in gas today.
Fords use a Schrader valve for the fuel pressure test port. I am pretty sure you could find several in a junkyard, or just buy a new one.
BBC Oil Pressure Port - Which One To Use S10 Racer Engine 6 01-24-2009 09:59 PM
700R4 4gear pressure port 42S10 Transmission - Rearend 2 05-24-2007 11:42 AM
TH350 -which is main line pressure port? sabino56 Transmission - Rearend 6 01-07-2007 02:35 PM
Oil pressure port on 351M cboy Engine 8 06-14-2005 02:15 PM
AOD throttle valve pressure port mustang66maniac Transmission - Rearend 2 01-08-2003 03:44 PM
