Fuel pressure reg for GM 70's engines ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2004, 09:59 AM
I have been driving GM cars for 15 years now and this is the first time I have a problem with mechanical fuel pump giving too much pressure . Result was gas in oil and cylinders .
I would like to avoid this problem in the future and install a fuel pressure regulator. I know that there is a Holley brand , does anyone knows some other alternative, cheaper then 40.00 Holley ? Engine is 69 Olds 350.
Thanks
Old 12-11-2004, 10:28 AM
tornado-tech's Avatar
Just curious, did you use a pressure gauge to come to this conclusion?
Old 12-11-2004, 10:36 AM
No, but flooding started after I installed a new pump and stopped when I installed spare, used one. I do not have a gauge I never needed it . I would like to know if someone else had this problem recently, maybe there is a bad batch out there.
Old 12-11-2004, 11:28 AM
It could be possible to get a bad one. A stock mechanical fuel pump puts out around 3-7psi. I would check it with a pressure gauge to see what both pumps are doing. If the new one is above pressure, it will overcome the needle and seat in the carburetor and cause the condition. Also the old one could be weak and you may have an internal fuel leak inside of the carburetor and the fuel pump doesn't have enough pressure to overcome the needle and seat. Without fuel pressure readings, its hard to diagnose.
