fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2011, 08:27 AM
Dan
Im running a holley electri fuel pump on my motor, and my $25 summit regulator is reading all over the place and i cant get it to adjust. also gas is going into my carb if i just run the pump without the motor running, bad regulator?
Old 04-04-2011, 08:38 AM
DoubleVision's Avatar
It sounds like the regulator is bum internally. That or the fuel tank doesn`t have a vent and the pressure build up inside the tank is overcoming the regulator.
Old 04-04-2011, 09:21 AM
75chev4x4's Avatar
Off topic a little if I may, but if I put a roller vortec motor in my older chevy truck I need electric fuel pump can I get one set to a specific psi our do I need a regulator too, what psi range should I be in? Thank you, sory op for the hijack.
Old 04-04-2011, 12:57 PM
techinspector1's Avatar
Wiki Edits: 326
5 psi max at the carb inlet for Edelbrock, Carter and Quadrajet.
6 psi max for Holley.
This is the type I normally use. Puts out 6 psi max at the pump, but by the time it goes through the lines and a filter, the pressure is a little less at the carb inlet. Mount it as close to the tank as possible. These pumps are designed to push, not pull. Some manufacturers say to install a filter between the tank and pump to prevent trash going through the pump. Others say that they don't want a filter there because if it gets clogged, it can burn out the pump. I install a good quality cannister type filter between the tank and the pump and then change it regularly, with another filter at the carb inlet. Mounting the pump to rubber and then mounting the rubber to the car will save your sanity by eliminating the drone of the pump motor through the sheetmetal of the car. Think sand and gravel conveyor belt material.
http://www.summitracing.com/parts/MAA-4070M/
Old 04-04-2011, 07:42 PM
Probably a bad regulator. But, the best solution with an electric pump is a by-passing regulator. Electric pumps put out the same amount of fuel whether the engine is idling or at WOT; unlike a mechanical pump whose out put is proportional to engine speed thus fuel consumption. It is not good to dead head an electric pump which will happen almost at idle and certainly if this thing runs with the engine off, which is incorrect wiring, it needs to be off when the engine doesn't run for safety's sake. However, if it's dead heading it beats the fuel to froth and overheats the fuel and the motor reducing pump life. Back in the good ole days of the Bendix diaphragm pump, these things shut themselves off when the line pressure reached about 4 PSI, these more modern hi capacity turbo impeller pumps do not, thus the need for a bypassing regulator if that's the type pump you're using. The big thing you need to do is to wire this pump so it doesn't run if the ignition isn't on, there should be directions with the pump on how to do this.
Bogie
Fuel Pressure Regulator bprumos Engine 4 10-23-2010 03:51 PM
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 01:51 PM
Do I need to run a fuel pressure regulator? Saito General Rodding Tech 1 01-22-2009 06:06 PM
Do I need a fuel pressure regulator? mattson70 Engine 17 07-01-2007 08:03 PM
Fuel pressure regulator lluciano77 Engine 3 04-25-2005 10:26 PM
