fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2013, 09:45 AM
the youngone
Last journal entry: progressthe
hello
i broke my fuel presure regulator so i have to buy another one..
my settup will be the origional fuel lines and a tbi fuel pump..
but im running a carb. so need a regulator,. i want to use the return line becouse if im running on lpg i want the fuel stays pumping around . but what is the good regulator for my settup.. i saw this one 3-Port Fuel Regulator (Carbs w/return) Clear
thnx!
Old 03-15-2013, 08:07 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
What do you mean by "I want the fuel stays pumping around."?
Semper Fi
Old 03-16-2013, 02:45 AM
SSedan64's Avatar
I'm guessing He wants the fuel to be constantly circulating using the Bypass style Regulator.
Depending on how many Outlets you need you can narrow these choices down further.
Fuel Pressure Regulators - Universal - Gasoline Fuel Type - Return Regulator Style - Inline Regulator Location - Carburetor Regulator Usage - No Boost/Vacuum Reference Port - SummitRacing.com
Old 03-16-2013, 09:28 PM
the youngone
Yes if i m runnig lpg the gasoline is getting. Old after a wile . And if you keep it running arount it stays good . But the regulator is good the one i send .. ?
Fuel Pressure Regulator daveh Engine 2 02-15-2013 10:36 AM
Fuel Pressure Regulator bprumos Engine 4 10-23-2010 03:51 PM
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 01:51 PM
Do I need a fuel pressure regulator? mattson70 Engine 17 07-01-2007 08:03 PM
Fuel pressure regulator lluciano77 Engine 3 04-25-2005 10:26 PM
