Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel pressure regulator
Old 04-25-2005, 08:08 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Agreed on the regulator. However, if the regulator has another output, you can add another output there as a bleed off line routed back to the tank, just as a stock mechanical pump does, just figure up whatever size orifice you need, you could likely use a jet from a holley carb.
