Fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2005, 07:34 PM
lluciano77's Avatar
I have a Holley Blue pump. I want to get use it on a car I am going to sell. I have used the regulator that comes with the blue pump. I have used a few of them. They don't work worth a piss. The regulators will eventually be overpowered by the pump.
Does anyone have any recommendations for a 3/8" regulator that is cheap, will actually work, and will regulate at 5 to 7 psi?
Old 04-25-2005, 08:08 PM
DoubleVision's Avatar
Agreed on the regulator. However, if the regulator has another output, you can add another output there as a bleed off line routed back to the tank, just as a stock mechanical pump does, just figure up whatever size orifice you need, you could likely use a jet from a holley carb.
Old 04-25-2005, 08:12 PM
camaroman7d's Avatar
Not real cheap but the Mallory regulators are as good as any out there. I have run them on several cars and never had a problem. The holley regulators are pretty bad. I have not tried their newer ones (and probably won't), I'll stick to what I know works.
Royce
Old 04-25-2005, 11:26 PM
lluciano77's Avatar
I was looking at the Mallory 2 port. The Comp 110 I had ran for years with no problems. The motor eventually burnt up.Then I switched to the Holley blue pump and regulator. Big mistake.
Fuel pressure reg for GM 70's engines ? Olds 69 Engine 3 12-11-2004 11:28 AM
Fuel pressure drops when electric fan turns on Palmtrees57 Engine 3 09-04-2004 02:12 PM
fuel pressure jtcamaro Engine 1 06-01-2004 01:29 AM
Fuel Pressure on Edlebrock Perfomer 600 trick66 Engine 1 03-22-2003 05:10 PM
fuel pressure question for a 350 SBC HotRodF100 Engine 15 05-13-2002 03:29 PM
