fuel problem gas tank or fuel cell - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2011, 09:53 PM
2006strat's Avatar
Braggen won't get you anywhere
Building my first truck(s10), and was wondering if anybody has used the stock gas tank with in-line fuel pump? Is it possible? Really don't want a fuel cell in the back please let me know. all info will be gratefully appreciated. Running sbc. maybe holley blue if any help.
Old 04-03-2011, 02:15 AM
Last journal entry: Some More Roll Cage Fabrication
Depending on the year you might be able to remove the pump from the sending unit and replace it with a tube/pickup an reinstall the sending unit. Then you can keep the factory fuel guage and use the power feed wires to run the new pump. Heck, you could utilize the fuel return line if you want.
If it is a newer year engine the guage and pump power feed will only work with the stock ECM. However, you can still utilize the wiring at the tank and just "hi-jack" the wiring at the ECM in the engine compartment.
Obviously this requires some fabrication, but it can come out real nice. As long as your engine is not too radical and doesn't need larger fuel lines.
gas tank or fuel cell? RCMJ Hotrodding Basics 5 11-13-2010 09:19 PM
Fuel sending unit cover (fuel cell) heyjude076 General Rodding Tech 0 05-21-2008 07:35 AM
Custom Aluminum Fuel Cell Problem chevy3600 General Rodding Tech 8 12-26-2007 02:28 PM
Cross-Link Polyethylene Fuel Cell/Tank texastomeh General Rodding Tech 1 11-22-2006 11:39 AM
Fuel Cell-Tube Type Fuel Level Sending Units Stupido1 Engine 3 06-11-2005 07:31 PM
