fuel psi when open cutouts? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 09:55 PM
I have a 468 and i put elect. cutout on it.
I run 7 psi fuel when i first installed cutouts it ran not to bad is this right?
I droped it down to 6 psi and tryed to drive with cutouts open
and the motor started to crackel and pop approx. 2nd gear flooring it.
the temp shot up to 210 to 215 (i have alummium heads should i worry about this)
I need some help!
Old 06-24-2010, 10:04 PM
cool rockin daddy's Avatar
Please take a deep breath and re-post your question. Very hard to understand as you wrote it. Thanks.
Old 06-24-2010, 10:14 PM
ok
i put elect. cutout on my truck.
I was getting on it (with cutouts open) and the temp went up to 210 to 215 approx. very fast
i have alummuim heads should i worry about the temp?
the other questions is: what psi on fuel
when i open the cutouts.
i had the psi on 7 psi is this right
Old 06-24-2010, 10:49 PM
ericnova72's Avatar
More for Less Racer
Fuel psi shouldn't even matter to how the exhaust is, at all.
Temperature rise on heavy acceleration is normal, and more quickly seen on a temp guage with the increased thermal conductivity of the aluminum heads. As long as it comes back down to normal after a minute or so it is fine.
215 is not even hot at all, 240+ would be time to worry.
What carb are you using??
Old 06-24-2010, 10:51 PM
830 super street
hydrogen booster / more mpg hottrodz Engine 39 08-28-2008 03:09 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 03:54 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Setting fuel PSI? BADASS Engine 1 03-05-2004 05:59 PM
no fuel inside carb when i crack the throttle open Moteman Engine 2 09-18-2002 05:57 AM
