fuel pump???
Hello,
My throttle body injected 1995 Chevrolet K2500 recently quit while driving up the road. It started right back up then immediately quit. It did this twice more and then would not start at all. I checked the fuel filter which was full of gas, for flow. OK there. I checked the fuel pump relay with a meter and it was fine. To see if it is a wiring problem, is threre a way to check to see if the in-tank fuel pump is getting power without dropping the gas tank? Thanks |
i dont think there is a way to check it without dropping the tank..seeing that it is a 1995 did you check your fuse box? there should be a fuse for the fuel pump, if so make sure you check that. if the fuel pump itself is good it could also be the strainer inside the tank...
-james- |
Fuel pump
Hot wire where the relay plugs into the wiring harness or fuse block, battery voltage to fuel pump, with a fused jumper wire and listen for the pump to start running. If it doesn't try tapping on the bottom of the fuel tank to see if it'll start. If it does the odds are the pump is bad. If it doesn't check the fuel pump wire at the connector at the tank. Usually the fuel pump wire is gray on a Chevy. If you have voltage there check to be sure the fuel pump ground is connected, usually a black wire. It'll be the heavier of the 2 black wires if you have 2 at the connector. The other black wire is the ground for the fuel gauge.
| Oil leaking near fuel pump..what the heck??? | HotRodF100 | Engine | 13 | 01-08-2012 05:03 AM |
| 93 Plymouth Acclaim fuel pump relay | 78 monte | Electrical | 14 | 04-19-2007 03:09 PM |
| efi fuel line sizing / fuel pump | Blob | Engine | 2 | 09-25-2005 12:25 PM |
| Electric fuel pump bad or not? | HotRodMan | Electrical | 4 | 09-10-2005 09:47 PM |
| Lean backfire | Camaro76 | Engine | 5 | 04-15-2003 05:45 PM |
