Fuel Pump ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2008, 07:42 PM
Fuel Pump ????
My car (mid '70's) quit on me today, it's not getting gas. I can pour a bit into the carb and it runs fine but after I quit bottle feeding it kills again. It ain't sucking the gas up through the line and clear fuel filter. I pulled the line off the side of the carb and sucked gas all the way up to the carb, then put the line back on and bottle fed it some more but when I stopped it killed again and this time I can see the gas all running back out of the see through fuel filter until the filter is almost empty. At first I thought it may be a clogged filter so I replaced it with a new one but it still did the same thing. What else could it be? Can anyone verify this before I pull the fuel pump off?
Old 05-26-2008, 07:53 PM
poncho62's Avatar
Wiki Edits: 5
Bad fuel pump.........Pull the line off the carb, crank engine and it should spit fuel out the line.........
Old 05-26-2008, 07:55 PM
Wiki Edits: 31
try to run it on a boat tank or stick a 3/8" line in a 2 liter soda bottle, with a hole in the top. put some down the carb and see if it takes the fuel.. if it does you got a clogged line/ tank... sounds like the pump to me tho
Holley Electric Fuel Pump Woes streetrodderbn Engine 13 04-24-2014 07:37 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
