fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2010, 06:09 PM
fuel pump
I'm going to use an electric fuel pump for my SBC. Should I just remove the push rod for the mechanical pump? Obviously, it would serve no purpose, but I thought I should ask the experts. I'm a bit of a newbie, so I don't want to do anything stupid !!
Old 05-05-2010, 06:15 PM
ericnova72's Avatar
More for Less Racer
Yes, remove the pushrod and mechanical pump, cover the hole with a block off plate as this area is open to the oil pan area.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
No fuel to carb, do have fuel at pump inlet - replace? bruceg Engine 8 04-22-2010 08:41 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
