fuel pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2012, 05:22 PM
fuel pump
I have a 1995 gmc pick up sierra I replaced the fuel pump and fuel filter the truck will start and run for a few hours or days and then suddenly shut off and won't start again. sometimes it would kick in and start but now it won't start at all. Can anyone please help me I am desperate have been stuck on the highway had to have a tow truck pick me up, have gotten stuck 35 miles from home then it started about an hour later
Old 12-04-2012, 02:12 AM
DoubleVision's Avatar
You'll have to check the fuel pressure. My dad has a 98 GMC and one day it wouldn't start. I checked the fuel pressure and found it 3 psi below it's recommended fuel pressure so as you see, even if the pump is providing pressure, if the pressure isn't up to factory measure it won't start. Hard to believe 3 psi below would have a effect on it, but it does. We played around with it by replacing the filter and the pressure came up another 1 psi, which was enough to make the truck idle, but the second the throttle was pressed it would go dead. We replaced the fuel pump and it's ran fine since and that's been 4 plus years ago.
Old 12-04-2012, 04:04 AM
fuel pump
I would have a complete scan done on the engine. 1995 Is OBD1 every shop doesn't have a scanner for pre-1995 computers. The reason I say this you could have codes stored and you think nothing is wrong. Here is just a sample of the codes your truck's computer reads. OBD-1 Diagnostic Trouble Codes. Check out this forum. They are talking about the same problems you have. Info: "Truck won't start" checking spark and fuel pressure - ChevyTalk --The Social Network for Chevy Fans
filter, fuel pump
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
