Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 08-07-2007, 06:52 AM
Cape Cod Bob's Avatar
Cape Cod Bob Cape Cod Bob is offline
fuel pump assembly -bad? all fixed
Now that I have my fuel tank out and the fuel pump assenbly removed how do I make sur the pump works/don't work before I plunk down $300 for a new one .Thanx
Old 08-07-2007, 08:28 AM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
re: fuel pump assembly -bad?
were you having problems before dropping the tank?
What vehicle?
Do you have a pressure gauge to read the pressure on the fuel rail?
Old 08-07-2007, 10:22 AM
37 plymouth coupe's Avatar
37 plymouth coupe 37 plymouth coupe is offline
re: Fuel pump assembly bad
I assume your fuel pump is electric and inside the tank. Some vehicles with electric fuel pumps have a special oil pressure sending unit (Vega for instance) that, if bad, will not allow the electric fuel pump to work. Check you oil pressure sending unit if it has two wires on it. I have used the Vega sending units on my oval track Fords, dragster and even my street rod simply because of the feature that will shut down the fuel pump if oil pressure drops. Also, cars with electronic fuel injection have a safety shut off switch (in case of an accident) I have seen these triggered and will not allow the fuel pump to work. Need to know...year, make, model!
Old 08-07-2007, 01:19 PM
THANX for the responses. It is a '97 Dakota. Electric fuel pump in the tank. Would not start. Has spark because squirting start fluid in intake will run 'till that burns off. Opened fuel line at coupling on frame and cranked. No fuel came out. Tested wires going to tank and found hot wire on only one wire measured to ground, and only when cranking. This may not be the correct way to test? Did not get any response from earlier thread so went ahead and removed tant and pulled pump assembly. With pump assembly out ,I put 12 volts to plug connectors and it ran fine.
Now I assume something must have to tell the pump to turn on. I assume there should be voltage present whenever the key is in the run position.
Am I correct?Where should I look ?
Thanx again.
Old 08-07-2007, 06:17 PM
1ownerT's Avatar
1ownerT 1ownerT is offline
There is a fuel pump relay under the hood, in the Power Distrubition Center on the left wheel well. The fuse for it is there as well, it is fuse #1-20a
Old 08-07-2007, 06:45 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I am not sure about your truck, but I had a Chevy Tahoe do that and it was a bad ignition key. Seems the key had a memory chip in it for security and the chip lost its memory. Had to make the chip relearn. It was easy to do. Turn the ignition on and just wait 10 minutes and it started right back up.
Old 08-09-2007, 09:40 AM
Turns out it was the fuel assembly. The pump in it still made noise and pumped a little when in a bucket and no lines attached, but not when hooked up. Must have been worn out impeller or what ever is used to pump. I put in a new one and put it back together and runs OK. Only thing I need to do is get the new rubber line I put on the outlet over the ridge as the clamp will not hold. I found out the hard way, on the road. Fortunatly in front of my brothers in law house. The line popped off. I put it back on and will need to do a more permanent fix at home.
Also need to R&R the filler neck as moving it around has caused a drip when filling and I will only put in a 1/2 tankful for now.
Does anyone know the pressure that is develeped by the pump? I thought I had that clamp on as tight as I could with a 1/4" nut driver.
THANKYOU to all for the great help.
Now I can get back to working on my '31 .
Old 08-09-2007, 11:58 AM
1ownerT's Avatar
Fuel pressure should be 49 psi +/- 5 psi at idle, this is at the fuel rail. If it is above 54 psi the regulator is bad.
Reply Back to top
« Fuel Cell | Sbc 400 »
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "fuel pump assembly -bad?"
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 5 08-16-2005 03:58 PM
Bad fuel pump??? ffcagle34 Engine 2 06-20-2004 11:15 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 12 05-21-2004 04:05 PM
