Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Pump block off oil leak
Old 06-18-2012, 09:36 AM
1F9O4R7D's Avatar
1F9O4R7D 1F9O4R7D is offline
I am running a sbc with a fuel pump block off plate and I can't seem to stop the minor oil leak. I have replaced the gasket and tried silicone and I still get a drip. Heres the issue now... The last time a took the plate off the change the gasket I snapped a lower bolt when I was putting the plate back on. The bolt snapped inside the block and there is no way I can drill it out. Does anyone seeing a major issue with me permanently bonding the block off plate to the engine block? This seems to be my only option right now. What type of bonding product should I use?
Thanks in advance
