Fuel Pump block off oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 09:36 AM
1F9O4R7D's Avatar
I am running a sbc with a fuel pump block off plate and I can't seem to stop the minor oil leak. I have replaced the gasket and tried silicone and I still get a drip. Heres the issue now... The last time a took the plate off the change the gasket I snapped a lower bolt when I was putting the plate back on. The bolt snapped inside the block and there is no way I can drill it out. Does anyone seeing a major issue with me permanently bonding the block off plate to the engine block? This seems to be my only option right now. What type of bonding product should I use?
Thanks in advance
Old 06-18-2012, 05:38 PM
FWIW
I would clean both the block mating surface and the plate with acetone, and immediately use some permatex (not silicon) and install the plate and let cure for at least 25hr before starting engine.
ssmonty
Old 06-18-2012, 05:46 PM
Richiehd's Avatar
JS-70
and I might add if its one of those Chinese chrome ones, scuff the side that adheres to the block with your whizzer wheel (Scotchbrite) that chrome is always an issue securing the sealer. Make sure those other bolts are not too long.
Old 06-18-2012, 05:57 PM
1971BB427's Avatar
RTV Ultra Black gasket maker should seal it if you let it sit overnight. Wont even need to use a gasket with it.
Oil leak between oil filter adaptor plate and block HotRodMan Engine 3 04-23-2011 11:36 PM
20 year old Carter mechanical fuel pump leak? bubbahotep Engine 8 07-12-2010 05:22 PM
78 caprice small block(oil leak) smurbs Engine 1 04-08-2008 10:22 AM
1962 chevy pickup - Oil leak between canister and block? shad9876 Engine 3 01-16-2008 01:57 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 02:56 AM
