fuel pump block-off plate - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2009, 04:31 PM
I am using a mechanical fuel pump block-off plate, but it didn't come with the fasteners. Can anybody tell me what fastener I should use ? It should be the same bolt that you use for your mechanical fuel pumps.... but I do not have one..... so do not know what bolt it is.... this is a Dart little M block, but that shouldn't matter.
Thank you !
Old 04-16-2009, 05:16 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
See fuel pump bolts, 4th from the bottom....
http://www.348-409.com/torquesm.html
Old 04-16-2009, 06:45 PM
Cape Cod Bob's Avatar
Just get some bolts at the hardware that fit and not to long.
Old 04-16-2009, 07:05 PM
Holder350's Avatar
Auto Parts Professional
If memory serves me right theres two 3/8" and two 1/4" or 5/16"
Old 04-17-2009, 08:19 AM
Thank you All !! The answer is clear now.
fuel pump failed during carb overhaul?! pcoghlan Engine 5 02-22-2009 09:44 AM
electric fuel pump? runn141 Electrical 4 01-03-2009 03:19 PM
Big block water pump on small block! TVR383 Engine 14 04-15-2008 07:43 AM
should i use a holley blue top or a manual fuel pump? 406 ss monte Engine 22 12-10-2007 07:39 PM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
