No, there are different size line possibilities depending on the application and a lot have a smaller line on the output side. i have seen several different configurations over the years. A lot of pumps have fittings that can be changed but I have also seen some that at least one side cant.
Must I use an 3/8" line to 1/4" npt fuel line pump inlet adapter ? My 62 Chevrolet 327 CI / 300 HP has a 3/8" fuel line yet it uses the same fuel pump as a 62Chevy with a 283 CI or a 250 HP / 327 CI engine that is equipped with a 5/16" fuel line. Those fuel pumps have 1/4" npt inlets and outlets.
As far as I can determine, the only difference in AC Delco 1957 - 1962 Chevy 283, 327 and 409 fuel pumps is the clocking of the inlet and outlet. They are all rated at 5.5 psi to 6.0 psi output pressure.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
