Fuel pump choice - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2013, 04:27 PM
Fuel pump choice
Hi all, I had my first go at drag racing last weekend and had a ball. Even managed a couple of respectable times Unfortunately my car died 200 meters from home at the end of the day. On closer inspection in turns out my fuel pump had destroyed itself. One magnet had become unstuck in the electric motor and had been rubbing on the armature. The magnets were in pieces and everything smelled real bad from the heat. The pump was one of Holleys newish hp series pumps rated at 150gph. I could just purchase another one the same and put it back in, but am concerned it might do it again. Was this just a bad pump or are these units not that great? If so then what would be a good pump for me to use that won't cost me a small fortune? My engine is a 408 sbc with AFR 195 heads, decent cam etc etc pumping out around 450 horse's. I pull about 6500rpm and the car should be good for some high 12s on the quarter. Do I need the 150 gph pump or could I run something a bit smaller? I drive this car on the street mostly with wife and kids with me so something quiet is definitely required.
Old 03-01-2013, 06:14 PM
bigdog7373's Avatar
Of course it's fast
Why not just use a mechanical pump? They are way more reliable than inlines.
If you are set on the electric pump then use a holley blue or red. One is quieter than the other, can't remember which.
Old 03-01-2013, 06:23 PM
gearheadslife's Avatar
MentalMuffinMan
I'd call holley
1) to see if they'll replace it
and
2) they might want to see the failure to see if it was a faulty pump or design..
and where you running a return line? or was it deadheaded.. at the regulator..
as that = death to pumps..
Old 03-01-2013, 06:46 PM
bigdog7373's Avatar
Of course it's fast
Good idea about calling holley.
Old 03-02-2013, 01:06 PM
Have to agree about getting in touch with Holley, I plan to do that. I can't run a mechanical pump as there is simply no room between my engine and the chassie rail. I'm not going to run a Holley blue or red as I've spoken to just too many people that have had issues with them. Done lots of asking and the outcome seems that the little 100gph carter pumps will pump plenty, are super reliable and quiet.
I haven't got a return system but am thinking I about changing it to one.
Old 03-02-2013, 01:19 PM
MentalMuffinMan
ya fuel flowing through the pump cools it, with no return line you are cooking it.. but call holley you never know they might replace it..
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 8 06-04-2006 11:56 PM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
