Fuel pump, electric choke and windsheild wipers on same wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2008, 04:20 PM
Hey guys, would I be able to splice my electric choke and electric fuel pump both off of the ignition wire going to my windsheild wipers?? I can't seem to find any other accessory to splice off of without someone saying "NO DON'T SPLICE OFF OF THERE!!" I guess splitting the power between any two things will lower their output.
Old 06-05-2008, 04:34 PM
You can trigger the fuel pump relay with that wire, but I wouldn't run the pump directly from it.
Old 06-05-2008, 04:39 PM
SSedan64's Avatar
Elliott is correct. The relay amp draw is minimal. Pump draw is high.
Old 06-05-2008, 06:09 PM
Oh I forgot to mention, I'm not using a relay....
Old 06-05-2008, 06:27 PM
Then there is virtually no place you can safely tap without problems. Buy a relay, they are cheap and easy to hook up. It will make sure you always have a good clean current going to your pump. Without one, you are just setting yourself up for problems. Spend the $6, do it right, then you won't have to do it again. If you run it directly off any switched circuit, it WILL burn out your ignition switch.
Old 06-05-2008, 06:58 PM
What kind of relay do I ask for??
Old 06-05-2008, 07:03 PM
Basically any 4 pin SPST 12v relay, preferably 20amp or higher.
This would be fine:
http://www.radioshack.com/product/in...ductId=2062477
Old 06-05-2008, 07:17 PM
SSedan64's Avatar
Pizzaman, here's a good thread about relays for different accessories.
A question for you electric choke guys
And this link that carsavvycook posted in his post.
http://www.6066gmcguy.org/BoschRelay.htm
Old 06-05-2008, 07:23 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Pizza:
I thought this had all be covered, including the instructions on how to wire it here yesterday?
Commonly known as "the Bosch relay" ... it is available with or without a mounting bracket.
NAPA Grote 448405 relay
Have a good look. It's the same relay as the Radio Shack one in the preceding reply.
I'm not sure how many amps your fuel pump draws, but according to the instruction sheet at the link I posted yesterday ... that Holley choke cap only draws 10 amps. Therefore ... if your fuel pump draws less than 20 amps, you could theoretically run both devices from one 30 amp relay.
I would recommend installing an in-line fuse between the battery power and the relay ... as close to the source as possible. "The source" COULD be the big terminal on the starter.
Internally Regulated Alt... Only Way To Go!!!!! hotrod389 Electrical 3 10-15-2006 06:41 PM
