fuel pump/ fuel lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2009, 02:47 PM
hi i have a ? about a 1979 camaro z28 we have a 355 sbc motor, patriot 202 alum heads, edelbrock performer manifold ,edelbrock 600 cfm carb. the car originally had 2 fuel lines and a vent line. one line was fuel into the fuel pump and then it had another return line back to the tank. Does the car need to have a return line? the mechanical edelbrock fuel pump i ordered 80 gph 6 psi only has a fitting for fuel into pump no return. I think the vent line from the tank runs up the left side of the car to the can in the front. the car has factory a/c . any help answers would be greatly appreciated. thanks bad apple
Old 03-12-2009, 03:29 PM
Hello I hope this helps you out. I have a chevy 96 s 10 that uses three lines. The biggest line will be your main line and the smaller one will be your return line. The littlest one will be your vent line. I do believe that is right for that part. The person i bought it from put a carbeurated 350 and I use only the main line and the other two they just cut off at a certain point and left them alone. I have had no issues running my carb this way. I use a cheapy mr gasket fuel pump wich ran me 40 bucks. With a carb setup you will just need the main line and will not use the other two. That should be all you need. I am guessing with that camaro it did not come with fuel injection since that was not big until around 1985 so you should be good to go. Hope anyone else can maybe chip in some info as well. Take care.
Eric
Old 03-12-2009, 10:43 PM
fast68's Avatar
likes chevy trucks & boobies
hi there,
well if you have the 5/16" return line on the car then i would run a pump with the return port yes
the vent line will be the smallest one and it runs to the charcoal can up front
good luck
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
should i use a holley blue top or a manual fuel pump? 406 ss monte Engine 18 12-10-2007 07:39 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
