Fuel pump help - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 02:03 PM
Fuel pump help
Hey guys I have a problem with my holley electric blue fuel pump. The pump is pretty much brand new and works fine when i turn the key to ignition when the engine is cold. Once I run the engine for 10 minutes or however long and shut the car off then go to turn it back on, the pump won't come on!! It is like as soon as the the engine heats up then is shut off and then the key is turned back into ignition the pump doesn't come on. Any suggestion of what this could be??
Thanks,
Keith
Old 10-06-2008, 04:18 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
A couple of questions.
Where is the pump mounted, up front, or back by the tank?
What size wire are you running to it?
I take it you are running key on power to it, from the ignition switch.
If it is back by the tank, and you are running small diameter wire to it, it could be heating up, from too much resistance.
Holley Electric Fuel Pump Woes streetrodderbn Engine 13 04-24-2014 07:37 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
