Fuel Pump help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2010, 05:35 PM
Andy79Z28's Avatar
Fuel Pump help
I am adding nitrous to m car. I purchased a larger fuel pump Mallory 250 ( I have a 140 now dead headed) the new pump has a fuel return output on the pump. My plan after talking to many techs was to use my current fuel system delivery and split it up front. Current line from tank to pump and line to front is 8an. Split it before the regulator, add second regulator for nitrous. Ok now here is the issue do I have to use the fuel return line or can I still dead head the pump. My concern is that with the return line connected will the pump flow less gph up front.
Car specs cars best is 11.34@ 117.6mph 1971 LT-1 Stock lower end not bored you know steel crank pink rods trw 11.1 pistons, balanced and all the race mods to crank.
Was told that this setup should support up to 175hp hit of nitrous. I know the fuel return is so the pump returns the excess fuel to the tank but have thoughts that it may take away some needed fuel for the nitrous use.
Any suggestions would be great.
Old 03-27-2010, 06:05 PM
ericnova72's Avatar
More for Less Racer
Set-up correctly the bypass only returns to the tank the fuel that isn't used by the carb and nitrous system. We run a bypass on the nitrous side just to make sure there isn't an air bubble in the fuel line to the nitrous solenoid, which can cause a boom . 250 hp shot.
Old 03-28-2010, 04:29 PM
Andy79Z28's Avatar
Bypass line
Ok now my fuel cell has 2 fittings on it.... One is supplying the fuel pump the other is capped off and both are at bottom of fuel cell. Can I hook up the bypass to the capped off fitting at bottom of cell, or do i have to add one to the top of the fuel cell?
Old 03-28-2010, 04:36 PM
ericnova72's Avatar
More for Less Racer
You don't want to put the returned(and possibly slightly aerated/frothed) fuel back into the cell that close to the other outlet/pick-up point. It needs to go back in somewhere away from the outlet, the farther away the better.
Any reason why you didn't just add a second line and another Mallory 140 pump rather than one bigger pump on a single line? A seperate dedicated system for each is a better way to go.
Old 03-28-2010, 07:31 PM
Andy79Z28's Avatar
other pump
Well...i have a mallory fuel filter with 2 outlets. Was not sure if i could drive 2 pumps from the same filter..... and thought it would be easier to just use the 1 larger pump and y off of it up front.
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 08:31 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 01:04 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
