Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-22-2005, 04:06 PM
bowtiebadboy's Avatar
bowtiebadboy bowtiebadboy is offline
first timer
fuel pump help
ok one thing is establish here i am an idiot
so I'm cleaning my room and I find a fuel pump that my friends dad gave me. He said when you but this on just be sure to tighten the bolts that hold the push rod so I tighten them as tight as they will go. Then take the fuel pump off and make sure the rod didn't fall so im really happy(because it didn"t) then I disconnected the fuel lines and the one from the tank to the fuel pump comes of pretty easy then I go to the pump to the carb line and its striped in so I use a little break free and it still wont come so i take it off it the fuel filter so I go clamp the old on in the vice and get it off with great difficulty then I notice that the fuel line has two kinks(question number one should i unkink them or get a new fuel line?) so then I go back and check everything over and i notice that the push rob fell down(question number 2 how do i get it back up in there?)
thanks for any help
Tyler
Old 05-22-2005, 04:11 PM
jpelli's Avatar
jpelli jpelli is offline
re: fuel pump help
You can push the rod up with your finger, and just make sure that the pump lever is under it when you replace the pump, also use a new gasket. Replace the fuel line it is not a big expense. Joe
Old 05-22-2005, 04:52 PM
first timer
re: fuel pump help
no luck its like stuck in the bottom i tried with my finger and pliers and a screwdriver
Old 05-22-2005, 06:09 PM
first timer
re: fuel pump help
anybody got any other ideas
Old 05-22-2005, 06:56 PM
nick62877 nick62877 is offline
re: fuel pump help
worst case , just unbolt the fuel pump plate that's bolted to the block. or use a magnet to pull the rod up. if you get a pair of needle nose pliers in there , you should be able to grab the rod and push it forward , then get a screwdriver or finger in there to hold it while you sneak the pump lever under the rod. it can be tricky since that rod gets so darn slippery. it will have ya cussing but it can be done.
Old 05-22-2005, 07:09 PM
solidaxel's Avatar
solidaxel solidaxel is offline
re: fuel pump help
I have had luck using a hack saw blade to get under the end of the rod and pushing it up.
Old 05-22-2005, 07:13 PM
curly5759's Avatar
curly5759 curly5759 is offline
re: fuel pump help
Long ago I gave up trying to push that @#$#% rod back into position. With just a little more effort you can remove the 2 bolts on the fuel pump plate and get a hold of the rod. I usually remove it, smear it with a light grease or vaseline to hold it in position when I reinstall it. Saves agravation.,
Old 05-22-2005, 07:36 PM
71 c-10's Avatar
71 c-10 71 c-10 is offline
just a kid and his truck
re: fuel pump help
haha i rember this is how i found this great board lookn for a how to on a sbc fuel pump. Get a new line, with the right size ends, if needed get a flair tool kit if you cant find the right lenth line to bend up. get a bender from the parts store or use a decent sized socket and warp it around that to make your bends, keeps you from krimpinig it. With the push rod, take the 2 lil bolts out pop the plate off and let the rod slide out and put some grease on it and stuck er up there. good luck
Old 05-22-2005, 08:40 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
re: fuel pump help
In case its not known on the front of the block their are 2 bolt holes in the casting... The bottom hole goes all the way through to the pump rod... If there is a bolt in that bottom hole take it out but keep it handy (to put back in place so oil will not come out above 3K rpm)... Have another bolt with long threads or allthread rod that will screw into the hole deep enough to contact the pump rod... Remove the fuel pump adapter cover and the rod can be pushed back into place then hand tighten the bolt coming from the front till it locks the rod in place... Replace the adapter cover and fuel pump then remove the bolt retaining the rod in place and put the shorter bolt that you removed back in place... GM made it easy for you but its not always known...
Old 05-23-2005, 08:16 AM
johnsongrass1's Avatar
johnsongrass1 johnsongrass1 is offline
Race it, Don't rice it!
re: fuel pump help
If you put the #1 piston on TDC, the pump rod will be fully retracted, then use a bolt to hold the rod in place, then install pump, the replace bolt with a shorter one.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "fuel pump help"
electric fuel pump recommendations stea Engine 2 06-27-2004 08:38 PM
Bad fuel pump??? ffcagle34 Engine 2 06-20-2004 11:15 PM
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 12 05-21-2004 04:05 PM
Fuel pump desperate help please 78 monte Engine 2 10-28-2003 08:09 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
