fuel pump keeps running! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2009, 03:13 PM
Hi
I've got a 1992 305 TPI Chevy engine running a S&P harness in a hotrod. Recently, when I turn off the motor, the fuel pump keeps running on & on & on. I've had to disconnect the battery to stop it. Reconnecting the battery seems to reset it. I did disconnect the fuel pump relay - but it still stayed on. However when I disconnected the oil pressure switch it stopped. Any ideas whats happening???
Old 09-11-2009, 04:01 PM
SSedan64's Avatar
Bad pressure switch or incorrect wiring. Does pressure switch supply ground or 12V?
Old 09-12-2009, 10:35 AM
Not sure about the aftermarket harness, but the stock harness uses two methods to power the pump. There is a relay controlled by the computer that switches the pump on for two seconds when you first turn the key to START to prime the fuel system. The oil pressure switch is wired in parallel to this relay and takes over once the engine starts. Both provide +12v to the pump. Either one could be bad and cause the pump to stay running.
Old 09-18-2009, 12:38 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Sounds like the contacts within the oil pressure switch are 'welding' together slightly. The factory switches are pretty heavy duty to handle the full current of the fuel pump, are you using a larger fuel pump, or is the oil pressure switch not a factory one made to switch larger currents (other than turning a dash light on)?
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Jet Boat Fuel Pump Question(s) ezobens Engine 22 09-02-2009 10:52 AM
87 Suburban fuel pump help needed Mustangsaly Engine 14 10-29-2007 10:04 AM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 01:39 PM
Carb size to small???? brainsboy Engine 50 08-14-2005 05:04 PM
