fuel pump location - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2011, 05:57 AM
fuel pump location
ok then
help needed as usual. im building a 32 5 window and have put the fuel tank in the trunk up against the rear bulkhead now due to piss poor planning i cant find a good location for the fuel pump,so what problems will i get if the pump is mounted just above the top of the tank,i was thinking that the fuel would run back to the tank every time the motor is turned of and starting may be a problem? the pump will be an edelbrock electric unit.thanks russ
Old 05-19-2011, 06:49 AM
Electric pumps really need to be mounted below the fuel level, they dont provide a lot of suction, so they need gravity to keep them fed. remember too, that the fuel acts as a coolant and lubricant for the pump vanes, continous dry cycles will wear the pump out faster. What about an intake pump.
Old 05-19-2011, 04:15 PM
ok i did a bit of a search,i know i should have done this first ! it seems the main point everyone mentions is that the pump needs to be gravity fed to get it going so its back to the drawing board and mount it on the chassis under the tank. piss poor planning strikes again.
69 mustang race fuel pump/filter location mike69 Engine 5 12-27-2015 10:32 AM
1989 Nissan Fuel Pump Location David Tuten Engine 2 03-27-2007 01:22 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Fuel Pump Location william27103 Engine 5 06-24-2005 02:27 PM
Electric fuel pump location pcesak Engine 20 03-28-2004 02:23 PM
