Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Pump Making Loud Noise
Old 08-24-2006, 01:37 PM
fitzwell fitzwell is offline
Napa used to make a mounting kit.....rubber biscuit with a stud out of each fine. Pump needs to be mounted as low and close to the tank as possible. Make sure you use a good, high capacity filter before the pump.A normal 3/8 inline filter will not get the job done......................don't ask
