fuel pump pickup an fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2013, 06:06 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I am upgrading the fuel tank in my 1986 olds cutlass with a tank from a buick gn. I am putting an intank electric pump in. I am running a new 3/8" feed and return and was thinking about having two -6 AN fittings welded on the pickup to adapt to the larger line. Problem is though it does not seem like I have a lot of clearance above the tank for a 90* AN fitting. Are there special connectors that are more shallow compared to other an fittingsso I dont have clearance issues. My other thought was to bend my new line like the factory did and just remove the old pipe drill a larger hole and epoxy or tig the new line in place. Any ideas you guys have?
Thanks
Carter pump NPTF fittings? staleg General Rodding Tech 2 09-09-2012 01:00 AM
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
fuel pump fittings? tinman386 Hotrodding Basics 13 09-09-2010 03:38 PM
PS Box, and Pump Fittings, I have no clue.. obengston Suspension - Brakes - Steering 6 07-17-2010 08:06 PM
Pump To Tank Fittings stinger12 Garage - Tools 8 07-20-2008 12:19 PM
