Fuel Pump Power - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 11:40 AM
Fuel Pump Power
Im putting a electric fuel pump on a 69 lemans with a 403 olds motor and im running a regulator with the pump. I dont realy know what i should run the power to but im thinking the accessory on the key switch. I dont know the pump is a push style it dont kick off at at any psi which it does 5.5-9 psi and i only want it to run when the car is running.
Old 08-16-2012, 12:22 PM
JeffB's Avatar
Bad Idea! Always run an electric fuel pump through a relay with the proper size wiring,this will do a good job for you Mr. Gasket 40H Fuel Pump Harness With 40 Amp Relay | eBay and you will have a safe system.You could add in a HD toggle switch into the circuit as an option.
Old 08-16-2012, 01:23 PM
OK i got it all hooked up thinks for the help
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
no power to fuel pump 34master Electrical 4 11-30-2009 07:27 AM
Fuel Pump power loss DjTy Electrical 0 12-13-2006 09:05 PM
Troubleshooting Fuel Pump Power on 87' Corvette edge Electrical 1 07-02-2006 06:12 PM
fuel pump power loss joseph brown Electrical 2 06-01-2006 03:30 AM
