Fuel Pump Pushrod/ Pump Mounting Plate (SBC) - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2010, 12:55 AM
--Chevy 350--
I have been reading that once you remove the pump there is another plate behind it that can be removed to allow better access for removing the pushrod. Can anyone shed some light on this for me, or even better does anyone have a picture showing the plate behind the pump and how to remove it?
When I was down there it looked like the place the pump mounts up is actually cast into the block?
Old 07-10-2010, 05:59 AM
GMC boogie's Avatar
There are two 1/4" bolts left holding the plate once the pump is removed. A gasket goes behind the plate.
http://www.summitracing.com/parts/TRD-2310/
Old 07-10-2010, 11:08 AM
Thanks- guess I should have cleaned it a little better, I couldn't even tell there was a seam there.
Mechanical Fuel pump... 88 SBC (Picture) BRSleeper2 Engine 26 07-21-2008 10:55 PM
mechanical fuel pump sbc 350 GMR Engine 4 06-20-2008 07:00 AM
SBC Fuel Pump Adapter chrisgarrison Engine 2 12-27-2004 01:05 AM
vapor lock, sbc, hot fuel pump Walker Engine 1 07-19-2004 10:31 PM
SBC Fuel pump pushrod lluciano77 Engine 3 11-16-2003 11:19 PM
