Fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2006, 11:07 AM
Fuel pump question
Hey all. I realize a leaking diaphram in the fuel pump can allow "fuel" to get into the oil, could it also allow "oil" to get into the fuel? I'm thinking not, but i'm not sure. Thanks for reading my post!.
Keith
Old 11-25-2006, 03:10 PM
DoubleVision's Avatar
I don`t believe so, since oil in the fuel pump area isn`t pressurized like the fuel is. When you change pumps, pack the new pump with lube in the spring area, since this area doesn`t have a direct oiling, without lube heat build up will ruin the pump in short order. I usually use moly or white lube.
Old 11-26-2006, 07:43 AM
kain13's Avatar
every time i use a mechanical pump when they break i end up with feul in the oil never again will i use a mechanical pump electrics are just as reliable now if not better
Old 11-26-2006, 02:45 PM
Fuel pump problems?
thanks fellows.
Keith
Old 11-27-2006, 06:40 AM
Technical Support Barry Grant
When ever you're using a mechanical pump in a performance application it's a good idea to use a seal behind it. Seals-it makes these: http://www.sealsit.com/fuel.asp
Old 11-27-2006, 07:00 AM
aka Duke of URL
What a good idea...
Look at these also;
Electric Fuel Pump Question dmaggard General Rodding Tech 3 10-09-2006 02:35 AM
TPI 350 fuel pump *VERSUS* a Multiport 2.8L fuel pump boneyard Buick Engine 0 03-18-2006 09:40 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
Fuel Pump Shut-off Switch Question rumrumm Electrical 5 12-22-2003 12:15 AM
