Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel pump question
Old 02-02-2013, 08:01 AM
454C10 454C10 is offline
Pumps are rated as GPH. Typical at max flow (zero psi). Check the flow graph of the pump you want to use.
Best to use more pressure then regulated in down near the carb. I also prefer to use a return line.
Most aftermarket pumps are loud, expensive, and don't last long (motor brushes wear out). I like to use the MSD 2225 efi pump with an Aeromotive return style fuel pressure regulator (requires a 3/8" return line to the tank). I like these pumps because they are quiet and very durable. Their brushless motors last for years and years. Plus if you ever decide to go efi, then the fuel system is already setup.
