fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2010, 07:59 PM
fuel pump question
I have been piecing togother parts to finish my engine and I got this fuel pump for cheap. It is for SBC and bolted up good and all seems right. I havent fired up the engine yet. My question is the fuel pump has a vent on it, is that an issue? Where do I hook it up to?
Old 04-30-2010, 08:36 PM
sedan delivery's Avatar
fuel pump
if you are talking about an outlet that has threads, this would be a return line to the tank to recirculate the gas to help eliminate vapor lock. this you can plug off if you want.being your car has no return line.
Old 04-30-2010, 09:04 PM
It is not threaded it is like a vac line.
Old 04-30-2010, 10:22 PM
NWayne's Avatar
It's exactly what Sedan said. You can plug it off or go to autozone and buy a cheap one without the return line.
electric fuel pump question sexypizzaman Engine 26 05-19-2015 07:13 AM
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Question on electric fuel pumps and fuel cells. eric32 Hotrodding Basics 14 05-11-2009 07:53 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
