Fuel pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2013, 07:16 AM
67L 67L is offline
Fuel pump question
What size fuel lines are the pressure ratings of fuel pumps based on? I need 6psi with 1/2" fuel lines for a recent sbc 383 build. Thanks for the help.
Old 02-02-2013, 08:01 AM
Pumps are rated as GPH. Typical at max flow (zero psi). Check the flow graph of the pump you want to use.
Best to use more pressure then regulated in down near the carb. I also prefer to use a return line.
Most aftermarket pumps are loud, expensive, and don't last long (motor brushes wear out). I like to use the MSD 2225 efi pump with an Aeromotive return style fuel pressure regulator (requires a 3/8" return line to the tank). I like these pumps because they are quiet and very durable. Their brushless motors last for years and years. Plus if you ever decide to go efi, then the fuel system is already setup.
Old 02-02-2013, 09:54 AM
bigdog7373's Avatar
Of course it's fast
I prefer a mechanical pump. Lots of good high flow units out there. You could also go with a piston syle pump if this is for a race application. The only electric pumps I like are the in-tank ones. I had 2 in-line pumps leave me stranded before I went back to a mechanical pump. I've had that same one for 3 years now with no problems ever.
engine, fuel delivery, fuel pump
fuel pump question southernculture Engine 3 04-30-2010 10:22 PM
Fuel Pump Question scottishcajun Engine 6 02-12-2008 10:58 PM
Fuel Pump Question sexypizzaman Engine 2 12-22-2007 05:11 PM
Fuel pump question HemmiGremmie Engine 5 02-12-2005 02:27 PM
Fuel pump question Bluepen Engine 13 03-16-2004 08:43 AM
