Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Pump question w/pic
Old 02-05-2011, 10:08 AM
001mustang's Avatar
001mustang 001mustang is offline
Originally Posted by dion
It smells like raw gas. There's one line from the tank to the pump and to the carb. The pump is mounted on the frame under the driver side door. Could very well be pressure, that would make sense. It's been this way since I bought it about three weeks ago. 360 engine. It passed smog at the beginning of Jan so I don't get why this is happening now. The weird thing is that it doesn't do it all the time. There's some days when I'll drive all the way to work and won't smell any gas and then other days where you just can't breathe.
let it idle.
pull a plug.
is plug black then its rich.
if rich the new pump may be overpowering carb as others said.
verify there are no loose vent lines or leaks.
