Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Pump question w/pic
Old 02-05-2011, 10:13 AM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: New Gas Tank
I would check the evaporative system out. It seems I remember the canisters were noted for getting fule backed up into them from the tank.Seems to happen more so on a full tank than less on a half tank or less?
There is a check valve in the tank fitting for the evap system that sticks and raw fuel gets in there get sucked up into the canister . Do you even have the evap hooked up properly?If the hoses are just swinging in the breeze that could do it also.
