fuel pump and regulator help..
I just got my new procomp blue electric fuel pump and regulator.. i hooked everyting up and turner the pump on to set the pressure... but no matter where i turn the regulator, to it stays at 7psi.. any body else using this regulator? any ideas?
without the engine running.. its not ready to be fired again yet...
I'm not recommending that you just hook up a hose and flow fuel into a bucket, as without the restriction to flow as posed by the carb, the settings you make would be as meaningless as the one you have with the system dead headed. Bogie |
Without your engine running there is no where for the fuel to flow to, so the pressure can not drop. As long as it's not blowing past the N&S right now you'll be OK to start off with. Just make sure to check the pressure when you get the engine running.
i started the motor yesterday.. and the guage at idle reads around 9-10 psi and when i give it throttle is drops to 7.. i've turned the regulator all over the place.. and it still won't keep it at a steady pressure..
