Fuel pump regulator placement - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 07:50 PM
I am installing a fuel line on a 79 camaro drag car I put an aluminum fuel line on the outside of the frame rail and brought it up to the firewall and attached to braided line where I was going to mount the regulator my question is should I mount it on the firewall or build a mount welded to the frame( it would end up being in a perpendicular line between the carb and dist but lined up with the outside of the frame rail) and bring it up about 1 foot and mount the regulator and take the line around to the front side of the carb. The car doesnt have fenderwells so that option is out. For some reason I remember something about it not passing tech if it was on the firewall.
Old 05-10-2007, 09:03 PM
chevymastermind's Avatar
drive it like you stole it!
Last journal entry: engine
they sell regulator mounts at like summit racing and they mount to the carb somehow. or a personal favorite thing to do for me wouls be mount it on the wheel whell
Old 05-11-2007, 02:42 AM
ericnova72's Avatar
More for Less Racer
Drag techs don't like them on the firewall because it puts them in line with the flexplate or flywheel area. Best place is somwhere forward of the carb, so that the fuel isn't fighting the g-forces from the launch after it has been regulated down. Let the g-force be with you ( boy, that's a bad pun, but I couldn't resist it).
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 17 10-09-2004 10:58 PM
