Fuel pump relay and electric choke - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2013, 04:31 AM
Hey guys,
I'm replacing my '89 Camaros TBI 305 with a carbed 383. I found an unused rear defogger connector in my dash wiring that would make for a very convenient toggle switch location on the dash just below the lighter. Could I use this connection for power to both the fuel pump relay AND the electric choke, just by running jumper wires through the firewall to these components? The pink/black wire in this connector pigtail has power only in the run position, not in accessory. Vehicle wiring is not my strong point, so the simpler the better. Thanks for input & info!
Old 03-13-2013, 06:28 AM
Bonneville462's Avatar
I don't see why not, those rear defoggers take a lot of juice, 30 amp possibly.
I'd try to run the car without the choke..
Old 03-13-2013, 03:25 PM
Upon closer inspection, maybe I could toggle switch the always hot (12 ga) orange/black wire (its on a 35 amp circuit breaker)? The pink/black is an 18 ga wire stemming from the 'hot in run' 10 amp gages fuse. Or is this overkill? I have no idea what the choke heater requirements are. I'm in AZ, so the choke may not be necessary, but I'd still rather have it functional. Thoughts?
Old 03-13-2013, 06:21 PM
Just run a wire from the distributor to the choke.
What Relay to use for my Electric fuel pump ponyxpress Electrical 3 07-08-2011 11:35 AM
95 gmc jimmy fuel pump won't shut off/fuel pump relay garystrosnider Electrical 7 10-28-2010 07:10 AM
Fuel pump, electric choke and windsheild wipers on same wire sexypizzaman Engine 8 06-05-2008 07:23 PM
electric fuel pump RELAY ONEGALONLY Electrical 5 05-10-2007 07:15 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
