fuel pump running but no gas to carb? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2008, 09:09 AM
just started happening.. Barry Grant 220 fuel pump is on and running. No gas is spraying into carb? plenty of gas, gravity fed from fuel cell. correct fuel lines, connections are correct. I had someone look at it yesterday and it turned on started fine. 30 seconds later it stopped spraying gas to carb and engine died. fuel pump continued to run??
Old 07-30-2008, 09:49 AM
Double_v23's Avatar
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
Fuel filter is clogged, line is collapsed, or there is a blockage on the inlet of the carb. Maybe the car is out of petrol?
The only reason for not spraying fuel would be that the fuel bowls are empty. start there.
Old 07-30-2008, 01:16 PM
Technical Support Barry Grant
Is this a HR220 or PS220? Is there fuel in the bowl itself? Is this an existing install or a new one? If it is a new install prior to start up did you fill the fuel bowls up before turning the pump on? What carburetor is on it?
Help with fuel bowl level. Leaking into carb! scapegoat Engine 7 05-28-2008 09:30 AM
Starter won't start and fuel pump won't pump after engine reinstall Porschev Electrical 26 02-16-2007 04:43 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
fuel pump bigwoodbass66 Engine 9 12-29-2005 02:21 PM
Carb rebuilt but won't start now.... ecrusch1987 Engine 4 11-10-2004 07:56 AM
