fuel pump shuting off while engine is running.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2012, 04:33 PM
Ok I have a 84 firebird that some body put a carbed 350 with a edelbrock performer and with a external electric fuel pump ran by a toggle switch and it pumps gas but once the car is running it stops pumping? Im confused what would cause this?? I bought the car about a month ago and it ran fine until yesterday.. Any ideas?
any ideas how i could re wire this?
Old 09-27-2012, 10:13 PM
How about a little more info on the fuel pump. What brand pump is it? Where is it mounted? It should be mounted in the rear of the car below the tank. You should have a 100 micron filter between the tank and the pump. It can be wired to a toggle switch or wired to the ignition switch. I prefer the ignition switch so it turns on and off with the key. There should be an 30 amp fuse on the +12 volt wire to the pump. Make should you have a good ground to the pump.
Old 09-27-2012, 10:32 PM
put a mechanical pump back on it
Old 09-28-2012, 02:46 AM
SSedan64's Avatar
I recommend using a Relay & Oil Pr. safety switch.
Most likely a bad Toggle switch, Pump or loose wire.
Several wiring diagrams & cleaning instructions here, if Holley type.:
http://static.summitracing.com/globa...199r7914-2.pdf
Old 09-28-2012, 06:51 AM
I'll try to get some more info on the pump (if i remember right it is a holley) its mounted in the rear of the car below the tank and right now the toggle switch pretty much controls everything (spark and fuel) I really want to ditch the toggle switch but im clueless when it comes to wiringso ill look in to those diagrams and see what i can figure out. Thanks guys!
Old 09-28-2012, 09:04 AM
electric fuel pump wiring harness
Jegs has a reasonably priced wiring harness for your electric fuel pump. JEGS Performance Products 10564 JEGS Fuel Pump Harness and Relay Kit Here is the instructions for the wiring harness. http://www.jegs.com/InstallationInst.../555-10564.pdf Looks like it would be an easy installation.
Old 09-28-2012, 05:02 PM
I got it figured out fuel gauge does not work and was out of gas Thanks for the help guys im be sure to use the links you pointed me too.
96 k1500 running out of fuel bad pump or no fire??? Dagwood03 Engine 7 08-05-2011 11:27 AM
fuel pump keeps running! hitecsedan Electrical 3 09-18-2009 11:38 AM
fuel pump running but no gas to carb? dhomsey Engine 2 07-30-2008 01:16 PM
Sunfire, died and wont start back, fuel pump is running, no gas getting to filter jordan2011 Engine 6 04-21-2008 06:01 AM
Key Off Fuel Pump Running greg67 Electrical 4 05-16-2005 08:49 PM
